Can you just put the mounting bolts in a different hole in the pedal box to level it? It should be higher than the elbows on the master/booster for bleeding purposes I would think.Alignment bolts came today. Easy enough to install. I'll bring it back next week for the shop to bring the rear into spec. They gave me 60 days to bring it back.
Since we'll be waiting a bit for the body panels to arrive and try for a NH title again, decided to work on the brake reservoir relocation.
We ( I) ground down one of the spacers, it was too close to the top that I couldn't get the bolt through.
My black tubing was only a little hard to put on, I didn't need to use the hot water in a coffee cup to soften.
I brought the lines to a local shop and they put the crimp rings on, just to make me feel safer.
Everything installed. Just have to wait 72 hours for the thread lock to cure before filling and bleeding.
I had to re-run one of the brake plugs, just needed to extend it 3 inches.
Is the reservoir supposed to be that tilted?
If I remember, it only has 30K miles. He took a lot of time cleaning and painting it all.That is a fine looking engine, looks brand new!!
Looks like they went to the Vet who's YouTube videos are OffTheRanch who got a, sort of, turn key. I believe he got a new frame but got Lonny's turbo motor/assembly.Guessing those parts weren't mine. Anyway, I was at the local Chevy dealer Friday and they stock the rear brake cables, I bought 2 for $25.
Go to an independent shop. The chains aren't going to be much help because they only go by the book. I went to a little two man shop that's been there for 50 years, it was great.Did you just have them align it to a cobalt? If It should not matter if I had an SS donor or will it? I drove up to NTB last night and they looked at me like I brought them an alien spaceship and would not touch it.
Nuker-
Are you referring to the alignment I had in May?Did you just have them align it to a cobalt? If It should not matter if I had an SS donor or will it? I drove up to NTB last night and they looked at me like I brought them an alien spaceship and would not touch it.
Nuker-
Please ask if they'd be able to do this for other BCM, I would ship mine there for that...I also found an independent repair shop that will change everything I want in the BCM for $100.
He will turn of the 10 minute door delay, set the mileage to 26 (amazing how many miles I've driven in my neighborhood) and turn off all the unnecessary idiot lights
I'd be interested in this also.I also found an independent repair shop that will change everything I want in the BCM for $100.
He will turn of the 10 minute door delay, set the mileage to 26 (amazing how many miles I've driven in my neighborhood) and turn off all the unnecessary idiot light on the dash.
