That was my first thought too... but I have reduced the spacer angle twice, and now are back to the original angle.Sounds like your binding problem for which you put in the spacer, when you did your pedal box re-align, might not be resolved. Possibly pushing on the brake pedal is putting it in more of a bind and that's why you're experiencing a worsening condition. You may try loosening all of the bolts and see if that frees it up.
The brakes have always dragged (Since Sunday, when I started driving the goblin). I'm not sure if they dragged on the donor car too.
If I purchase a new master brake, what years/models have the shorter master brake?The master cylinder has the spring to return the pedal. It's usually pretty stout, especially if you have ever tried to bench bleed one. Either the pedal box and associated linkage is in a bind not letting it return or there is something up with the spring in the master cylinder.
I would like for it to be away from the radiator, as long as it performs the same.
