While I had the bump steer gauge took the opportunity to adjust the rear also. Adjust corner weights and realigned.
Test drove, car is steady over uneven surfaces and bumps and very precise with steering input. The toe does not change when getting in and out of car as before, before had to set the toe with driver in car to get it close. With the removal of bump steering that is not the case. Steering does not self center as well with the reduced caster but is fine for me.
A recap of why the changes were made. Elected not to install power steering when building car, with only 600 pounds on the front end seemed unnecessary. On the rear suspension install ball joint extenders so that the car could be lowered and keep the geometry correct in the rear. Was also able increase the rear roll center height to reduce body roll. Install spherical bearing outer tie rod ends front and rear to make the bump steering adjustable. Hopefully someone that has put some miles on a as designed car will come by and test drive it for comparison.
Brad
