George
I made them. I machined them with a small flange and make it just fit. Then hollowed out the back side with a 1 degree tapper them made a plug with a 1 degree taper. Threaded the plug 8x1.25, drilled a hole in the face of the plug to put the bolt through and tighten. On one of the plugs you have to put a grove so that the balance chain tensioner get oil pressure. Do not know of any one the supplies them. Give me a call if you need to.Hey brad I’m working on a balance shaft delete and was wondering where you got those caps on the front? I found the bushings to press into the oil passages but the only thing I could find for the front end still had the sprocket for the chain. I want to get rid of that balance shaft chain and run the shorter one like you did.
Brad
