SliderR1
It's a little more complicated than that since the fans original wiring runs through that serial/parallel relay setup. I also want the HE fan to run pretty much any time the car is running, which could in theory be arranged through HPtuners using the original fan circuit, I think. I haven't checked the lower limit coolant temperature on the HPtuners setting for the fans on the PCM. Based on my previous post with operational theory above, both fans run in series on 'low' then in parallel on 'high' as the PCM interprets the coolant temperature. I guess my original thinking was to tie the HE fan into the HE system some way instead of 'coding' it to do what I needed through HPtuners and the coolant temperature. Definitely a good option to consider, though.
If I wanted to use the SER/PAR relay, as described above, I'd need to route the ground wire from the Goblin radiator fan back up to the fuse box, which isn't really a big deal. I'm going to check the software in HPtuners tonight to see how much flexibility it offers on running these fans. If I did it this way, I would also gain both low and high speed operation of the fans, which probably is a good thing...
