Dylan Stan
I thought this was an easy simple fix to the clutch switch that interferes with footwell cover and the Hood
Looks nice and simple to me. Good job. I just cut mine out completely. I wasn’t using the cruise control so I didn’t need it.I thought this was an easy simple fix to the clutch switch that interferes with footwell cover and the Hood
View attachment 9568View attachment 9567
Where did everyone cut off the top of their clutch pedal top and sensor bracket so it wouldn't hit the hood? Fairly low? If possible, please screen capture the pic above and add the cut off line. FYI: I think this is for SS/SC only models.I thought this was an easy simple fix to the clutch switch that interferes with footwell cover and the Hood
Thank you!!!
No problem, and if I remember, you dont even have to cut that much. I cut mine at the thinner spots. If that makes sense.Thank you!!!
