TomsGarage
Hey guys, created this thread to document the build of my track frame goblin. For my car I knew that I would want a lot of power, coming from liter bikes in the past. A popular option is getting the standard cobalt for $500-$700, and then supercharging it for another $700. Rather than build up the standard motor, I decided to get the already stout LNF motor. I paid a little more, but the engine is well worth it.
The 2.0 LNF ecotec motor is a beast. It's been used in us spec Atoms and also the 999 Motorsports MK2 (http://www.999motorsportsusa.com/tag/gm-2-0l-ecotech-lnf-engine/). While the cobalt itself had some faults, the motor is fantastic. Unique LNF features, compared to the standard Ecotec motors include:
Not as mild build, 650whp: http://www.aforwardmotion.com/ecotec-powered-ariel-atom/
With just an exhaust, intake, tuned on E42 these put down over 350whp/420wtq, plenty for a car that weighs 1400lbs and should be very reliable. The 2008 donor that I purchased also has the 315mm 4 piston Brembo brakes and optional LSD.
October 27, 2015
I just picked up a donor that will be used for a DF Goblin kit car. It is a 2008 Chevy Cobalt SS with 30k miles. It was totalled because of a rear end accident, perfect for this build. Other than the rear end damage it is a real gem and runs and drivers perfect. I'll be getting my frame in the second batch around the end of jan/mid feb. In the mean time I will start stripping my donor down to the required parts. End goal will be to have 300 RWHP in a ~1400 track/street legal weapon.
The car was purchased on Copart and I used A Better Bid as a Copart Broker. They charged $200 and also arranged shipping to AL to TX for $550. It ended at $2600 on CoPart and all said and done I paid around $3800 delivered at my door. I had listed it on uShip as well, but A Better Bid was able to secure the best rate since they are also a transportation broker. Shipping only took about a week and I highly recommend this broker.
Auction pictures:
Delivered in my garage!
- a twin-scroll turbocharger
- cam-driven high-pressure gasoline direct injection fuel system
- dual camshaft continuously variable valve timing
- sodium-filled stainless steel Inconel exhaust valves
- low-friction cast aluminum pistons with oil squirters
- forged steel crankshaft
- forged steel connecting rods
- cast stainless steel exhaust manifold
October 27, 2015
Auction pictures:
