JeffsGoblin
Tony, that might your key fob connector mentioned/pictured here: http://dfkitcar.com/forum/index.php?threads/2007-ss-sc-coolant-hose-route.522/page-3#post-7036
Like I said, that's going to be my first "fix", but I was thinking that wouldn't make much different since it's the end of the "chain", after all the controls.Make sure your BCM power wire is plugged in. I got all those same symptoms when I forgot to plug mine in. But if your lights are working, then that's probably not it. If your data wires are shorted at the OBD-II connector, then that could definitely be a problem.
Also, thanks for the tip. Once I quit looking for a little gray box (which is what my brain was sure went there), I was able to find that sensor in less than 2 minutes.That should be your ambient light sensor.
It is. I actually haven't quite connected all the plumbing yet. I wanted to finish electrical first, so I can get it wrapped and out of the way.Low coolant would indicate you don’t have communication. Unless it’s actuly empty.
Is that on the headlight harness plug? If so, then I don't. That block isn't even installed in the fuse box... I didn't even think of that being an issue for anything engine-related.Do you have this ground hooked up?
