BaltimoreHokie
When you have time, Can you post a picture of your set up?I am actually using an electric powder coat gun by craftsman. It was 40 dollars on eBay, and it works pretty well.
That's really interesting, looks a lot different then the ones I've seen. I think I want to get a kit at some point.Sure. Here's a link to the gun if you want to see it. I bought the power brick separate because it was cheaper than buying it together.
Really? I'll have to check it out.I am actually using an electric powder coat gun by craftsman. It was 40 dollars on eBay, and it works pretty well.
I used prismatic powders, and their bake is 12 minutes at 400 degrees. I could not smell any odor at all, even with my mask off.Really? I'll have to check it out.
Out of curiosity, what was your bake temp and time?
How was the odors given off during the bake? Was it really bad or ok?
Those looks great. Leave them like they are...i hate plasti dip on wheels. Seems like after a couple months getting it off is toughRims are here! Sadly, I couldn't get them in gloss black, so I chose opal. I think I will just plastidip them black and see how that works.
The pictures do not do the color justice. It looks really good and I might just keep them like this.
They look great as they are!Rims are here! Sadly, I couldn't get them in gloss black, so I chose opal. I think I will just plastidip them black and see how that works.
I can't seem to find one? I have looked all over the autozone site for one but I have had no luck.You definitely should replace that. Usually they come in a replacement set.
http://www.rockauto.com/en/catalog/chevrolet,2007,cobalt,2.2l+l4,1433735,brake+&+wheel+hub,caliper+piston+seal,14387I can't seem to find one? I have looked all over the autozone site for one but I have had no luck.
Thanks so much. I was looking for the wrong brake model I guess.
It was quite easy. I took white spray paint and sprayed it into a bowl, and after cleaning the tires with acetone I used a paintbrush to apply the paint.I like it! What did you use to paint them and how?
