Vacuum lines
JERMzSS
Can i get some pics showing exactly where the vacuum lines should be ran on an LSJ from somebody? I'm having low boost issues and i think i have some of them ran wrong. Thanks!
Yes, I have the same question. Where do all those vacuum lines go...
Lets start with the MAP sensor - do I have it pointed the right way? (with the brass fitting on the right side)
And that brass elbow vacuum line on the side - where does it go?
9032
Parson Green
Am pretty sure the brass elbow gets connected to the breather on the valve cover.
There's an arrow on the MAF (yes, MAF) sensor and, when the sensor is properly installed, said arrow points in the direction of the airflow.
Thanks Parson. I found the arrow on the MAF - inside the red circle.
The red rectangle is where I put some aluminum duct tape over the hole, as I have a small red air breather for the valve cover.
9116
askiles
The arrow should point towards the engine...so you have the MAF correct. The hole on the MAF housing is for a small brass nipple to mount. That will be for the vacuum hose that goes to the valve cover. I capped mine off, and put an breather filter on the valve cover.
Parson Green
That HVAC tape is great stuff but am wondering at what temp the mastic begins to break down.
Maybe double or triple up on the thickness of it just in an abundance of caution?
BTW, some people retain the vacuum hose and install a catch can at some point along its length.
Yeah, the HVAC tape is probably fine at the start of the intake, but I also used it on the wheel bearing caps, where it may get warmer. We will see!
I did put 3 layers of tape on the wheel hubs. Good idea to keep the vacuum lines.
Parson Green
Here's one implementation of a catch can.
"This is a universal oil catch can kit. It is intended for high boost applications where the factory PCV cannot flow enough to maintain proper crankcase pressure. It connects your crankcase vent tube to your intake tube. As the intake tube draws a vacuum it will pull the gases from crankcase, and if pressure builds in the crank case it will vent into the intake instead of to atmosphere. The catch can holds the oil as it accumulates in the can. It will need to be drained, how often?, that depends on how much blowby your engine has."
