baustin
One of the things I've considered changing about my build is the sway bar. I currently have the 06 SS SC 24mm sway bar. I'm under the impression that if I want to change to the 18mm FE1 style then I'll need to get the sway bar, the end links, and the bushings but the bushing brackets are reused.
Currently I have the end links that are just under 10" long. Bushings are still stock and are held in place by 1 bolt on each bracket, see images, they tab into the sub frame. I think I've read about some cobalt versions using 2 bolt style brackets instead of 1 bolt.
If I go the junk yard route for parts, is there a year range I should limit my search?
