Jammerthal
I've tried to troubleshoot this as much as I can by reading other threads and leveraging all automotive knowledge I have, but I need outside input please. Have a crank no start issue. Here's what I've done so far.
- checked all grounds and all fuses, both sides of the fuse with a test light and everything checks out okay.
- checked all my electrical connections. I originally had a question about the five pin purple connectors, but I'm pretty sure I have those right. I've also read about the eight pin connectors, but I believe I have those correct as well. The one closest to the head is designed so it can only plug in to the one that's supposed to, the other one only has seven wires in it, and the throttle body is working with the throttle pedal, so I think those are all in the right spots.
- check the fuel pump, it's running and pumping fuel. I disconnected the main line from the fuel rail and it's pushing plenty of fuel with the key on.
- checked for codes with my OBD scanner. Only have a few emissions codes and one for the mass air flow sensor. P0449, P069, P0452. Reader scans and clears codes just fine.
- checked for voltage on the coils, the center two pins give me 12 volts on the connector for each coil.
- I don't appear to be getting spark. The car has a hundred and 170,000 mi on it, and it doesn't look like the plugs have been changed the entire time, but it did drive into my garage and ran pretty good before disassembly.
- dash appears to be fully functional with all the lights turning on when the ignition turns. Steady no flickers.
- throttle body moves with the gas pedal.
- checked to make sure that the crank sensor was plugged in as well as all other sensors and plugs.
- The brake reservoir is empty as well as the coolant reservoir, they're plugged in but I don't think there's a safety kill feature for those if they're empty but could be wrong.
- it's a manual transmission and the clutch pedals tied back, hence it's able to crank.
It doesn't seem to even try to fire. Like I said, I have voltage to the coil packs so I'm assuming that electrical connection is correct. I've read a couple of threads with similar issues but none of what they did seems to fix my issue. Appreciate any help.
