OH that is a fun battle . Been there and done that also.Now that I’m done with chemo and fully recovered, it was time.
After a lot of looking around for donors, I just couldn't wait anymore and bought an 09 SS/TC in Nashville, TN ($6K) and drove it home to Dallas last week.
I started the tear down this week. It's moving surprisingly quick for having never done anything like this before... other than some stuff with my Wrangler Unlimited (lift kit, etc.) Huge thank you to the build guide videos!
Craigslist has worked really well for parting out what I don't need. Looking to recover more than $1K at this rate.
I'll post as much of the build as I can to my YouTube channel... www.youtube.com/aaronbuley
Haha yeah. We ended up using an engine hoist for the front and a jack for the rear and just rolled it out slowly.Looking good! That HF furniture dolly is not sturdy enough for the donor carcass, I did the same thing. Ended up using a set of wheel dollies (roller skates) to move it around. BTW, the kids are cute!
Latest Build Video -- Part 2After a lot of looking around for donors, I just couldn't wait anymore and bought an 09 SS/TC in Nashville, TN ($6K) and drove it home to Dallas last week.
that's assuming I'M doing it right. hahahLove the videos! its going to help a lot making sure everything is correct on my build keep up the good work!
Upper angle goes outboard, lower one goes inboard.front wheels on!
are they supposed to have that level of camber when off the ground?
what brake pads did y'all order for the supplied calipers?
you're saying one of the control arms is flipped? i thought they both were supposed to have the single bend in the front, right?Upper angle goes outboard, lower one goes inboard.
The steel bits bolted to the front suspension uprights. The two hole flange is supposed to be on the outboard side of the upright at the top and on the inboard side at the bottom.you're saying one of the control arms is flipped? i thought they both were supposed to have the single bend in the front, right?
interestingly, its the inverse on the old version. that's why i did it that way.The steel bits bolted to the front suspension uprights. The two hole flange is supposed to be on the outboard side of the upright at the top and on the inboard side at the bottom.
found the brake pad conversation --> http://dfkitcar.com/forum/index.php?threads/brake-pads.550/#post-19700front wheels on!
flipped them around. that did the trick, thanks!The steel bits bolted to the front suspension uprights. The two hole flange is supposed to be on the outboard side of the upright at the top and on the inboard side at the bottom.
