These two plug into the back of your turn signal stock.
Not necessary to start the engine.
This is your OBDII
This is your brake fluid level sensor plug.
This plugs into the small gray box that was on top of your donor's dash. It is a key fob receiver and tire pressure monitor.
This is the Horn plug.
These are cooling fan connectors. I think. I know the top one is.
Ambient air temperature.
The right I believe is for EVAP. Not sure about the other.
One of the O2 sensors.
AC plugs.
Not needed
Transmission main plug.
A lot of things will not work if this is not connected.
If you have not attached your shifter cable you will need to manually shift the transmission into park.
It will not start if the transmission is not in park or neutral.
Before you try to turn the engine over make sure you have looped the transmission cooler lines or you are going to have a mess to clean up.
Until you get your MAF tube hooked to your engine leave the MAF unplugged. The engine will run very poorly if it is plugged in and does not have air being pulled across it by the engine. It will run fine without it.
