The purple wire has no voltage even when the key is turned to 'start'.That wire (I think it 'requests' a start) is purple.
Frame is off the ground, axles not installed. I am at the end of video 21 or 22 and not finished all the details yet, wanted to get past the electricals first. I did jump it with a screwdriver and the starter spun, but I just can't get it to work with the key. I don't have the shift cable hooked up yet. If I go to the selector on top of the transmission, is park toward the front or back? I will get to the build thread soon and check it out. Thanks for the advice.Put it in neutral and lift your drive wheels off the ground, turn the key to ON position, keep your hands clear, then give 12v to the purple wire or stud and see if it cranks.
If it does, you might want to read about the middle 15 or so pages in my build thread.
You've got an automatic, right? Park is towards the back of the car. Two clicks forward should put you in neutral. Do you have wires plugged into the shifter? I don't think the car will start without that there.Frame is off the ground, axles not installed. I am at the end of video 21 or 22 and not finished all the details yet, wanted to get past the electricals first. I did jump it with a screwdriver and the starter spun, but I just can't get it to work with the key. I don't have the shift cable hooked up yet. If I go to the selector on top of the transmission, is park toward the front or back? I will get to the build thread soon and check it out. Thanks for the advice.
I am thinking the security light is the yellow one that looks like a padlock. It comes on when I turn on the key but goes out in 2-3 seconds.Not sure about the shift cable, mine's a 5-speed.
I probably missed this, but, did you say whether or not the security light is on, on your cluster? If it's on, you'll need to do a key re-learn.
I'll save you a bit of reading because my build thread is ...... long, my problem ended up being that a connection on the fuse block end of my engine harness had a slightly-deformed pin. I had to fix that pin, then it started cranking. But, there's a ton of good advice from our compadres in there, you may find something that helps.
The bottom line is, when you turn the key, the ECM decides whether the conditions are right to crank the engine. If they're right, the ECM provides ground to a set of three pins in the engine harness, which in turn grounds the correct pin on a relay in the fuse box. With that relay pin grounded, power flows to the signal cable on your starter. *edit* I might have said that wrong now that I think about it.
That's correct, and that's good, because it means your key is being accepted by your TDM. That's bad, because it would have been an easy fix!I am thinking the security light is the yellow one that looks like a padlock. It comes on when I turn on the key but goes out in 2-3 seconds.
One thing that may be worth considering; the donor was wrecked on the front left, which is the general area of the round connector from the transmission. The connector was damaged and the pins were bent a little. I straightened them and pushed the connector onto them. I am wondering if there should have been a plug attached there. The connection is not secure, nothing 'snapped' into place like with most connections.That's correct, and that's good, because it means your key is being accepted by your TDM. That's bad, because it would have been an easy fix!
I'd follow Lonny's advice and not get too far ahead of yourself. These are complicated systems and it would be a waste of time to troubleshoot something that's not actually broken, just not far enough along in the process to work correctly yet.
Don't know if the donor was running. I can turn the engine by hand so I know it is not stuck. Been talking to Lonny. He is helping me troubleshoot, and I have found a couple of things. Progress is slow but it is happening.Was the donor running when you took it apart? Since Lonny did the harness it’s not likely that the wiring is wrong.
It’s more likely that you have a connector that’s not plugged in all the way or one that got a bent over pin when you plugged it in.
