Mayor West
Hey friends,
I'm on the plumbing side of my build with the engine in and things starting to need connecting. I've put off a lot of these decisions because things evolve as I progressed and I didn't want to put myself in a corner with the wrong design.
Some notes on what's different about my build:
Thanks everyone for any advice/help!
Also, I do not plan on tracking this build. That's not the type of driving I'm going for. This is a nice-weather "just-for-me" sorta car. I'm not shooting for peak performance or top-of-the-line specs. I only upgraded the turbo because my stock compressor contacts the housing and I enjoy the build process, so a custom setup is a bonus for my pleasure. That being said, I don't want to do anything incorrect or set myself up for disappointment, failure, or future financial hardships due to something I could have avoided earlier in the build.
- I am using 16AN fittings for the majority of the radiator lines
- Normal hoses at the engine then connecting to adapters to get to AN through the frame tubing
- I have an S252 turbo with a ZZP T3 manifold
- There are no water lines
- There are only oil lines
- I have an external GFB 38mm waste gate
- I intend to use the factory boost control solenoid if possible
- I do not have the DF air/water intercooler, I am running an air/air intercooler.
- I have an atmospheric venting BOV, I believe this requires a blow-through MAF but I am not sure on the specifics
- I plan on running 93 octane with the stock fuel system
- My downpipe has two O2 bungs and I plan on eventually running a wide band when I get to that point.
- No cat
- No muffler
- Waste gate vents to atmosphere
- Since my turbo doesn't have coolant lines:
- I need to plug the two ports on top of the radiator inlet on the head... there's a two-in-one fitting, should i remove this dual port and plug it?
- I need to plug the side port on the thermostat housing that used to go to the K04. Threaded plug for this as well.
- Since I am not using the DF supplied intake pipes/etc for the intercooler, what ports do I need to add and for what?
- My donor came with a K&N intake pipe that I'm going to modify to reuse the MAF section. I think it has a vacuum line port on it as well but I'm not certain of its location or if I'll be able to reuse it.
- ZZP's custom tune section asks for the location of the MAF for tuning purposes, what am I likely to end up going with given my options?
- Regarding the MAF and the atmospheric BOV, what are the do's and don'ts for this? I believe the tune can accommodate for a blow-through MAF but I am not certain. I've also been told that I can run without a MAF if tuned for it. Thoughts? Pros/Cons?
- With a maximum power goal of no more than 380-400ish rwhp (regardless of mods, that's as high as I'd care to go)
- Is the 3 bar map sensor necessary?
- Are the Opel injectors necessary?
- Since I am using an external waste gate, can I still reuse my factory boost control solenoid as long as its tubed up correctly?
- Since I don't have the stock turbo, can any open ports be avoided, such as on the valve cover?
- Should I run a catch can?
