*** THIS IS NOT YET FOR SALE. LOOKING FOR BETA TESTER(s) - SEE BELOW ***
To firm up and fill in some info you all have been waiting for, I have populated a bunch of info below. All accurate as of --->July 28th 2020<---
Project name:
Up to this point, I really have not had a name for the project. Still not sure what to call it.
Official features:
- Airbag Bypass: Option to disable airbag light (also disables airbag warning messages in the information center)
- TPMS Emulation: Option to disable low tire pressure light (also disables low tire pressure warning messages in the information center)
- TPMS Enhancement: Option to adjust the tire pressure warning threshold to any value between 0 and 40 PSI in one PSI increments
- Door Switch Output: Option to pulse driver door trigger at ignition off to avoid BCM from staying powered up for 20 minutes.
- Startup Message: Option to enable a pre-defined (not yet decided) "welcome message" when the vehicle is started in the information center.
- On screen user menu to enable/disable/adjust features above. Demo HERE.
Unsupported features:
- PK3+Bypass: Option for key cloning (clone the chip in your key allowing you to use keys without chips or deleting the TDM ring around the key cyl).
Unimplemented feature ideas:
- Welcome Selection: Ability to select one of a few pre-defined welcome messages.
- Belt Minder: Some form of a seat belt reminder, possibly with the ability to wire in the stock seat belts.
- TPMS Learn: Menu option to initiate the TPMS learning procedure without having a stock remote control.
What is included:
- Digital vehicle interface
- 3D printed enclosure
- Vehicle integration harness (24" long, blunt cut ends)
Required Wiring:
- Power [RED]
- Ground [Black]
- GMLAN (Car Side) [Lt. Green]
Optional Wiring:
- GMLAN (TPMS Side - OPTIONAL) [Lt. Blue]
- Output 1 (Door Pin - OPTIONAL) [Orange]
Other Info:
- The firmware is upgradable, but for now, they must be sent back to be upgraded. If a new feature is released or a bug fix is needed, you would need to send the unit back to be loaded with the new firmware release.
- This is not a "real" product in the sense that it has not, and will not undergo the extensive research, development and testing that a normal product would go through. Keep this in mind and set your expectations accordingly.
- I’ll do my best to keep these supported, but assume that these are sold as-is with no warranty.
- Requires the vehicle to be equipped with working Cruise Control to navigate the menu.
Price:
- $200 USD, economy shipping within the continental USA included.
**I know it is a lot of money. If it makes you feel better, this price will not even come close to recouping the hardware R&D, let alone the software development.**
Availability:
- Once tested by beta tester or two, I will open these up for purchase. There will be a limited run of these. If you want to be put on the list to reserve one and be notified when they are ready, simply PM me and I will add you to the list.
Tester requirements:
- Further testing is required before selling these. I am looking for a tester who:
- Has a completed Goblin
- Is ACTIVELY driving said Goblin
- Has the TPMS (RCDLR) module installed
- Has TPMS sensors installed in the wheels
- Has the factory remote and knows how to pair the TPMS sensors with the vehicle
- Can be communicative about testing so I can quickly resolve any issues.
- Is not afraid of wiring or electrical.
- Benefits of being a tester:
- Half cost (fully refundable if you do not wish to keep the item for ANY reason)
- One off firmware with whatever "Welcome" message you would like (up to about 80 characters).
- You will instantly become cooler by having one of these in your possession. It will also magically add 100 HP to your Goblin.
If interested in being a tester, please shoot me a PM with name, phone number, vehicle details.
Reserved:
- Ark
- Peregrinus
- MisterDave
- Desert Sasqwatch
- WYGoblin
- Lechlis
- Torchandregdoc
- Todd M
- Devonrex
- Mayor West
- KSLunsfo
- Goblin Graber
- Brett
Supply dependant:
- AZmoto
- Sparvy
