Included - free of chargeBrad, just sent a PM, get me on the purchase list please. Sorry, can't beta test, not that far into my build.
Edit: how much extra for the magical 100HP extra option?
Correct - PK3+ Bypass works. I just don't want to be the guy you are mad at if the module failed and you were unable to start your Goblin because the factory PK3+ system was removed. I would recommend leaving the key ring plugged in and tucked under the dash "just in case".Brad,
You list "PK3+ Bypass" as an unsupported feature. I take that to mean it's a "use at your own risk" feature, but it works? It's the main reason I am interested in this unit.
Thanks.
Requires the vehicle to be equipped with working Cruise Control to navigate the menu.
I'd be interested in the module and would be more than happy to test/debug; however, I think these two items are deal breakers are for me since I used a base model that didn't have cruise or power locks.Has the factory remote and knows how to pair the TPMS sensors with the vehicle
im curious about this too, as my donor doesn't have cruise either i believe.I'd be interested in the module and would be more than happy to test/debug; however, I think these two items are deal breakers are for me since I used a base model that didn't have cruise or power locks.
TPMSI'd be interested in the module and would be more than happy to test/debug; however, I think these two items are deal breakers are for me since I used a base model that didn't have cruise or power locks.
perfect, all good, for a second i was worried.TPMS
The interface will work with or without TPMS. I just need a tester that has TPMS because I want to test as many functions as possible with one or two testers.
Cruise Control
Cruise control is required to navigate the menu(s). I will likely default the menus to the most common config so the module will work even without cruise. For example, the default config would turn off the warning lights and enable the door pin output (the primary goals of this project).
Price and info found HERE.I'm also interested (depending on price of course), Of course I have barely started teardown and just ordered my kit Monday, so I'm a long way from actually needing it.
Sorry, I missed that post while skimming through. I'm in if its a now or never deal. I guess I should be able to resale if something happens and my build doesn't get completed.Price and info found HERE.
I have one that has been "running" on my Goblin for months. That said, its a frame with a wire harness and battery. My goal is to get someone who is driving their Goblin as it is much more likely to show any issues than my static setup.I can't imagine that actively driving would have to entail much more than around the neighborhood, but Bradr might want a more thorough test of driving in all conditions.
