4/8/15 Preparing Donor Parts Video #15 In Progress
Engine wiring harness labeled, photographed and taken off for rework. Lots of prep work done on other parts. Some notable differences:
1. Brake Booster: Ours did not have an aluminum spacer. There was only 1 layer of foam and it was glued/stuck to the booster. Will have to find a foam replacement and see how it works when assembling the Goblin - not sure if the spacing will be OK without the spacer or not.
2. Radiator: We had an extra connector to the radiator fan - a black & white heavy gauge wire going to a coil on the lower left of the fan shroud. The docs say "cooling fan resistor" and it looks like it puts out a good bit of heat. I have seen motor starting resistors, but don't remember any as elaborate as this one. I'm assuming I can take out the fan and resistor wires from the Engine harness, correct? See picture:
3. When we pulled the axles, they came out differently from each other. The left one came out and left the transmission sealed. The right came out - with what looks like the bearing to seal the transmission. Originally we thought that there was something wrong with the right axle, but after looking at more pictures on other builds, maybe the left one didn't come out properly? See photos below:
I took the picture and the Left was on Top, but then it came out like this. Reality in these pictures is reversed: Left axle is on the Right -and- Right axle is on the Left.
Are we going to have a problem reinstalling the axles like this? Did we do something wrong and need to fix it? Will the right axle bearing go back in and seal well to prevent any leaks? I saw in Nuker's thread that he put in new axle seals - should we consider that?
Thanks!
Thanks!
