Vwsaabvt
I think I have everything on right, it seems like a lot of people post their pictures and get told their arms are upsidedown or on the wrong sides. So hows it look?
You already identified the main change. Other than that, if your hubs have an electrical connector that interfers with the DF parts, your can get a 3D printed hub bearing cap from DF.Little bit at a time, waiting on some gaskets and thermostat.
On the front brakes are the old videos still current? I think I'm missing the front brake hardware unless something has changed, I did search for the upright brackets forever until I realised they were now steel brackets and not the old style aluminum ones.
I bought new non abs hubs and stainless lines, guess I'll call df Monday for the hardware.You already identified the main change. Other than that, if your hubs have an electrical connector that interfers with the DF parts, your can get a 3D printed hub bearing cap from DF.
The rubber brake line now is longer, and no longer has a steel line on the swing arm. It goes from the brake caliper to the main frame all in one rubber line.
What bolt pattern? If it's the standard 5x110 could you share part numbers?I bought new non abs hubs
I have the same donor. Here are the Moog wheel bearing parts for the 5x110mm hubs. (The bearings and hub are all one unit)What bolt pattern? If it's the standard 5x110 could you share part numbers?
Those have ABS though, right? I'm looking for non ABS so I don't have to do so much work on the ABS cap, if I'm replacing anyway.I have the same donor. Here are the Moog wheel bearing parts for the 5x110mm hubs. (The bearings and hub are all one unit)
4x100 patternWhat bolt pattern? If it's the standard 5x110 could you share part numbers?
True, I ordered the flat cap from DF.Those have ABS though, right? I'm looking for non ABS so I don't have to do so much work on the ABS cap, if I'm replacing anyway.
I did too, but looking for an excuse to replace rusty but functional wheel hubs, ha.True, I ordered the flat cap from DF.
Thanks, I had spray cans made at the paint store that match my wheels. It wasn't much more than buying paint off the shelf, only $7 a can.The gold parts on the black engine look great!
I'm interested if it's not too much trouble.its a heater core hose off a police interceptor utility. if anyone is interested I can get a part number later.
Were the bushing difficult to install? Do you need a press or special tools?Got my ottp control arm bushings all installed today. I hope to get my supercharger painted and bolted on by the end of the week then the engine can come off the stand and have its first meeting with the new transmission and clutch.
I used my snap on balljoint press.Were the bushing difficult to install? Do you need a press or special tools?
Motorcraft DB5Z18472BI'm interested if it's not too much trouble.
Engine looks fantastic.
