KingChuck24
Ok so just tested the voltage on the fuse and it’s 0 when it’s in the run position. Is this a wiring issue then?
I would think that the fuses on the BCM would pop during a power surge before you fried the circuits, but I am also not sure. I think a fried BCM is unlikely though. can you check to see if any of the bare wires for the lights and turn signals are touching something metal?Could this be a fried bcm or something?
The Run/Crank relay coil gets power from BCM2 40A fuse in the fusebox, then the IGN SW 2A fuse in the BCM, and finally from ignition switch being in the run or start position.We are so close to finding the issue.
According to this map, the electricity flows from the Run/Crank relay to the IP IGN fuse. Your goblin isn't doing this.
The issue is one of these:
1. the Run/Crank relay is defective.
2. the Run/Crank relay is energizing the coil and the rear fuse box is defective, and isn't passing the 12V+ from the Run/Crank relay to the IP IGN fuse.
3. the Run/Crank relay isn't energizing the coil because it isn't getting power to the coil. (What could cause this coil to not get power?)
When the key is turned on, that relay should get power (both 12V+ and ground) to the coil on pins 85 and 86.
Test:
Does the Run/Crank relay click when the key is turned? If you put your finger on it, and someone turns the key, you should be able to feel it click.
