KingChuck24
If we went the route of getting a new fuse box is it a drop it or would it require programming?
Okay, so you aren't getting 12V+ to the ip/ign fuse. It should have 12V+ when the key is on. Did you test it with the ignition in the run position?Got back to working today and the new fuse box came in. We installed that with no issue and tried starting with the same result. The run crank relay is flipping back and forth extremely fast like last time when we tried to start it and the dash is blinking almost every light as well. Tested the ip/ign fuse for 12 volts and got nothing. This leads me to believe that it has something to do with wiring or it is some other underlying issue.
Wait... What? Now you do have 12V+ to both posts on the ip/ign fuse?Ok tried putting the jump pack on again with no luck. Something I have noticed is that the battery drops extremely fast, when the key is turned to the run position I can watch it drop about .01 volts every 5-10 seconds or so, not sure if this is normal but I didn't think so.
1. Checked continuity across the posts and it is good. There is not 12 volts across the two posts but, if I instead put a lead on a post and another on ground both of them have 12 volts.
Well if test #1 has 12V+, then we don't need to do tests 2 & 3, as the RUN/CRANK relay is working now.2. This could be it, between pins 30 and 87 I am only getting 4.3 volts, it was doing the same thing before though so not sure. Also when I attach the leads the dash turns on and disables the anti theft so not sure if that means anything either.
3. Good 12 volts
