April 2021 DF Kit Car Contest Announcement - Wheel Wednesday
Vwsaabvt
Wheel Make / Model: XXR 530
Front Wheel - Size / Offset / Bolt Pattern: 16x8.25 0 Offset 4x100
Rear Wheel - Size / Offset / Bolt Pattern: 17x9.75 25 Offset 4x100
Tire Make / Model: Toyo Proxes R1R
Front Tire Size: 225/45 16
Rear Tire Size: 275/40 17
jirwin
Rims: Konig Control
Front: 15x6.5 4x100 40mm offset
Rear: 16x7 4x100 40mm offset
Tires: TOYO Proxes R1R
Front: 195/55R15
Rear: 205/55R16
23281
For those who are curious, wider tires on the rear kept the front and rears on the same plane. My eye twitches every time I see someone with front tires that have a wider track than the rears.
SmsDetroit
Ok, seems everyone is jumping in, so my turn. In storage and these are the only good photos I have.
Vors TR4 17x8 30e fr, 17x9 35e rr, 5x110
Federal 595 RS-R 225/45-17 fr, 255/40-17 rr
Do you know if you need spacers. I ordered 9.5 for the rears and didn’t bother to check. Fingers crossed
With aftermarket struts and 255 tires on the 17x9 rim I calculated to have about 20mm (3/4 inch) clearance with no spacer. I used a couple different on-line wheel/tire calculators and the measurement for the stock Cobalt SS wheel/tire spacing as my starting point.
SmsDetroit
I’m running 9.5 out back with a 275. So hopefully it will fit. Might be right. I have the coil overs in the rear
