Worked through part 4 of the new video series tonight, and a couple questions came up. Disclaimer; I haven't done the labeling as shown in the video yet, so maybe I'll find an answer there, maybe I won't.
At 5:14, a taped union of tan wires is identified near the body to dash harness connector. In the video, the instruction is to pull the one loose wire from this union, cut it out and discard it. However, for me, neither wire in the union is loose; One runs to the ECM connector, and the other runs to the large light gray fuse block connector. Which one should be cut out?
At 7:05, the video says to set aside the loose blue and green wires. Is this pair of wires for the headlights/taillights? I've also got a roll of wires containing a yellow wire, a bright green wire, and several brown wires. Correct me if I remember wrong, but these are all in some combination, for the headlights/taillights, right?
At 7:41, the video says you should have a pair of wires for the fuel pump (in the video, they appear to be purple and gray). But I seem to have three wires for the fuel pump; a purple, a gray, and a tan. The tan goes to either the large light gray fuse block connector or the body to engine connector, I can't tell which because they're all taped up. Can I get rid of this tan wire?
