So I went about trying to adjust the camber of my back wheels per
THIS thread, and I really suck at this. I have the exact angle meter they recommended in that post, and the zero on it seems to change every time I move it. Additionally, I have the BC Racing coilovers, but there seems to be NO adjustability on the two bolts that hold it to the knuckle. So I gave up for the night.
Any tips for this? Do I do it with the wheels on the ground, or jacked up? I assume with the wheels on the ground. If not, maybe that's my problem.
Also looks like I have air working its way out of my coolant system, because now my cluster is reporting low coolant without having any leaks. I have to get another gallon of coolant tomorrow and add some. At least this is (probably) solid confirmation that my water pump is moving coolant around.
Finally, I haven't wired up my third brake light yet because I made a booboo. Since my clutch is bled now, I have to get in the car to start it. I was doing some work back there, and wanted to test something with a wire that gets power only with the ignition on, so I set my cheap-ass multimeter on top of one of the back wheels and hopped in. I started the car up, and I don't know whether my shifter cables aren't adjusted well or if (more likely) I am out of practice and forgot to take it out of gear before letting the clutch out, but my car lurched forward, stalled, etc. And my multimeter is now a pancake!
I have another one on its way.
