I may have one of those. If I can find it, I'll send it your way.That's awesome! congrats!
I am missing that red cap too... I'm also missing the red cover that goes around positive battery connection. Haven't been able to find one for sale anywhere yet.
That would be great! let me know, I can buy it from you.I may have one of those. If I can find it, I'll send it your way.
Thanks for checking.Ahhhhhh, sorry for leading you on, but the extra power wire I have floating around my garage is missing the red cover.
This. Your hand in all locations. Access the “temp” function on the dash for coolant temps, but touching the hoses and the rad all over is a good way to confirm coolant is getting all over.You just want to know if the heater loop is circulating? Or are you wanting to know if the engine coolant is circulating?
Either way, use your hand. Check if the little rubber heater hose loop is hot, or to check the engine coolant, touch the metal tube beside the driver's seat - It gets warm when the engine coolant is circulating.
left cable at trans goes to left side of shifter (driver's side). Easy peasie.Two preemptive questions:
In the above pic, the shifter cable on top goes to the LEFT side or the RIGHT side of the shifter?
In the pic above (not my pic), I believe I am missing the small adapter plate that mounts between the pump and the oil pan. Could someone please tell me what the ID # is on the baggie that contains this little kit?
Thanks in advance!
