BaltimoreHokie
Nice work!
Easier to go most of it off the car. DF has the measurements pretty much down to a science. We did the bulk of the work on the bench and then finished it in the car because I customized some of the wiring.I actually really like wiring a car. I have done a whole car from scratch. So maybe I will attempt it. Is it easiest to do on the car, or off the car? Or a combo of both. I can see the advantage to on the car would be exact fit.
Understood. Thanks...I am thinking I will go ahead and attempt it. What's the worst that could happen. LOL ;-)Easier to go most of it off the car. DF has the measurements pretty much down to a science. We did the bulk of the work on the bench and then finished it in the car because I customized some of the wiring.
Andy, great progress. My donor carcass is still sitting in the garage. Question: did you take your donor carcass to a wrecking yard or have someone pick it up? Did you have to surrender your title?Bye bye donor car. Time to get it all 100% prepped now. I need to clean and replace some of the parts from the front suspension. The coilovers parts are on their way. It’s coming along!
So I hauled it away and it is sitting at my shop/office. We have lots of space so it will just sit until I finish the Goblin, register it, and no longer need the Cobalt. We may just slip it into our scrap bin when it comes time. We will see. I would assume if you take it to a scrap yard they will want the title. Just to make sure it is yours.Andy, great progress. My donor carcass is still sitting in the garage. Question: did you take your donor carcass to a wrecking yard or have someone pick it up? Did you have to surrender your title?
Our recycling center wanted the title or a bill of sale in your name. I used the bill of sale.So I hauled it away and it is sitting at my shop/office. We have lots of space so it will just sit until I finish the Goblin, register it, and no longer need the Cobalt. We may just slip it into our scrap bin when it comes time. We will see. I would assume if you take it to a scrap yard they will want the title. Just to make sure it is yours.
What is a good source for the constant power? Is on of the 12v power outlets constant? Which side of the brake switch is the side?While working on your harness, leave a constant power and a ground available for the push to start button. Extend it all the way out to the key switch. Also add a wire to the switched side of the brake switch and extend it out to the key switch also. That way when you are ready to install it, you have everything ready.
