Yep. The Houston scca chapter put us in street modified, but reading some of the rules, super street modified might be more fitting. They did tell us at the last meet that they talked about us to make sure we are in the right class. considering there’s not many in our class and we are just having fun, unless someone complains, I’m sure we will stay in the same class.
Its E-mod. Street mod cars still have their production car frames. SS just means its a two seater. Your correct that no one is going to care until you get fast anyway. That just means they will go read up on the rules, but that is your job since it is your car. Hopefully it will be a problem for you sooner than later... : p
See section 18.1 A.1 under Kit cars page 151
Rules Here
"Members desiring approval of a particular kit car should provide the SEB with detailed information regarding the kit model and contact info, if available, for the OE manufacturer. For obsolete kit cars, the member will be expected to provide construction specifications, dimensions, and photographs for the SEB to examine and keep on file."
I have wrote them and I think a few others but have not heard back. Maybe if DF wrote them with technical specs we could get somewhere with the SEB.
STREET PREPARED takes things a little further than Street Touring. There are no limits on wheel or tire size, and there are several other modifications that go well beyond those in Street Touring – like the use of DOT-legal R-compound tires.
STREET MODIFIED allows engine swaps (within the same manufacturer), the addition for forced induction and any suspension as long as it uses the same attachment points. This is a class for the truly creative, and the cars sometimes end up with only a passing resemblance to their base. It’s the wildest of the classes that runs on DOT-approved tires.
With
PREPARED, you’re moving into pure racing machine territory. Prepared cars usually have no interiors, racing slicks or may even be tubeframe cars with fiberglass bodies. Often the cars that compete here are cars from the SCCA Club Racing Production and GT categories.
MODIFIED is everything from pure, purpose-built racing machinery such as formula cars and sports racers to cars that started out as production vehicles but may have different engines, heavily modified bodywork and racing slicks.
