Fozda
Yeah, I could see that!The size of this thing makes me think it might make a great front wing when it's no longer needed in the back.
When HAS it been needed in back? The car is heavily rear-weight-biased already; no extra downforce needed.The size of this thing makes me think it might make a great front wing when it's no longer needed in the back.
For me it's needed for aesthetics which is what I was referring to. $89 later and it's off my list of things to do. The bulk of my wing budget will be allocated to the front setup as it's actually beneficial.When HAS it been needed in back?
Is that based on experience or just speculation? I was under the same impression until I decided to try it because it's so cheap and picked up a whole second on a 40 second course that I've been running at for years and have done almost a dozen events with in the Goblin. The only thing that changed between events was the wing.When HAS it been needed in back? The car is heavily rear-weight-biased already; no extra downforce needed.
It would look cool across the front, where it can do some good
There's plenty of slack but I will have to keep an eye on the rubbing.Having it go under the steering lock out may cause the cables to get pulled as the suspension cycles.
So your saying Porsche, Ferrari and others have it all wrong? Interesting.There is NO speculating weight distribution when you have a tube-frame skeleton chassis with the full drivetrain AND fuel tank in the rear, both passengers TOWARDS the rear, and the small battery and radiator holding down the front.
It doesn't take a masters in mechanical engineering or physics to figure out what any semi-literate but observant teenager can see. If after all the above, a rear wing improved the track times, I think other issues were in play. See what happens with the wing up front. Can you say, "improved balance"?
No. Porsche, Ferrari, et al... have bodies that affect aerodynamics in many different ways, many of them requiring wings.So your saying Porsche, Ferrari and others have it all wrong? Interesting.
I'm guilty too - my apologies.Sorry AZmoto for blowing up your build log.
No worries. I only get stuff done about every month or so now so someone has to keep this log alive LOL!Sorry AZmoto for blowing up your build log.
