I got one too. I just noticed that the main pulley has six ribs instead of five. I saved the pulley from the donor. Hope it fits.
So nice!! Do you have a link for this? I want one.More stuff keeps showing up. At this rate I'm going to be forced to get a Goblin.
This guys did a great test of all of them and the RocketSocket came out on top. Interesting to watch.Just an FYI to anyone who hasn't discovered these but they are amazing. I have yet to find a stripped bolt head that they can't remove. A must have tool IMO.
Not sure how this LSJ discussion ended up in Paul's build log for his LNF?You can just change the alternator pulley to 6 rib, And put a 6 rib belt for no slippage when spooling turbo up. If you want belt size let me know and I will look up for you in morning. Pulley was only 13 dollars when I ordered 6 months ago
That's the exact video that led me to purchase them. I also bought the ABN stud extractor set which has worked well.This guys did a great test of all of them and the RocketSocket came out on top. Interesting to watch.
The discussion is LNF. The LNF crate I purchased from ATK has a 6 rib main crank pulley.Not sure how this LSJ discussion ended up in Paul's build log for his LNF?
I noticed this too. Is it going to be a big deal if it is one rib short on the pulley?The discussion is LNF. The LNF crate I purchased from ATK has a 6 rib main crank pulley.
According to HP TUNERS you can use the six rib pulley with the 5 rib belt just leave the front hole empty, so put belt on up against timing cover. Then you want have to change the alternator pulley just leave it 5 rib. Hopefully I want get in trouble for posting this sense I have a LDK MOTOR !I noticed this too. Is it going to be a big deal if it is one rib short on the pulley?
Thank you for looking into that.According to HP TUNERS you can use the six rib pulley with the 5 rib belt just leave the front hole empty, so put belt on up against timing cover. Then you want have to change the alternator pulley just leave it 5 rib. Hopefully I want get in trouble for posting this sense I have a LDK MOTOR !
AZmoto has a new LNF so I thought he would want to also no about the 6 rib crank pulley on his engine (PROBABLY HAS 6)
Woooo!! Stoked for you!! Good ol Arizona. Miss the dusty rain smell during the first rain of monsoon season. Hopefully things didn’t get too wet.It downpoured for like 10 minutes in Phoenix today. Even had a bit of hail. Of course it was the 10 minutes that the Goblin was going from the truck to the garage. Five minutes after they left it was bright and sunny again lol.
You're next! I saw it on the truckWoooo!! Stoked for you!!
Fire up the air compressor and blow everything off as soon as possible, otherwise the welds will rust up overnight.It downpoured for like 10 minutes in Phoenix today. Even had a bit of hail. Of course it was the 10 minutes that the Goblin was going from the truck to the garage. Five minutes after they left it was bright and sunny again lol.
