Vwsaabvt
the title says sold outany more of these F23 transmissions available?
@OptimizePrime did a fantastic write up of not only the differences, but also the swap process here: https://dfkitcar.com/forum/index.php?threads/guide-f35-to-f23-with-lsd-transmission-swap.2502/So I've been thinking/reading as about the F23 versus F35 for a LSJ car. What are the pros/cons? Cheaper to rebuild, and different gear ratio...but what else should I know if I were interested? Do they bolt up to the goblin frame or are different mounts needed?
Hey Kimberly! Do you know the FD on these transmissions? Also, would the team be willing to install a Quaife LSD for me before shipping? I’m not quite as daring as @OptimizePrimeTHESE ARE NO LONGER SOLD OUT!!!!
Guess who has these in stock NOW????
They'll be added to the store shortly & are $500 plus shipping.
~Kimberly
Please send an email to [email protected] so I can have that looked into for you. I do not want to count on my memory for that! LOLHey Kimberly! Do you know the FD on these transmissions? Also, would the team be willing to install a Quaife LSD for me before shipping? I’m not quite as daring as @OptimizePrime
As soon as the item is added to our store, it will show shipping costs once you add the needed info to calculate it. We're hoping to add it back to our store asap so keep your eyes open!Obviously shipping is dependent on location....but does anyone have a reasonable guess? $100 or $1000?
I've never shipped a transmission before.
That you want or need a new transmission?What would the reasoning\motivation for me to pull the trigger on one of these?
I'm going this route for FD change as well as I am already experiencing a slow 1-2 shift due to synchro wear. Seems that most say this one actually works better in high HP cars. Axle shafts would be weak point in f23 car IMHO.What would the reasoning\motivation for me to pull the trigger on one of these?
Because you already have your Goblin without the F40 frame mod and can't install the F40 6-speed.What would the reasoning\motivation for me to pull the trigger on one of these?
What exactly is modded on the frame to make the f40 work? Would using some additional spacers between the mounts fix it for us unmodded ones?Because you already have your Goblin without the F40 frame mod and can't install the F40 6-speed.
Technical, Dragon Motorsports Goblin 2.0 has been ordered but not welded yetBecause you already have your Goblin without the F40 frame mod and can't install the F40 6-speed.
