Bajakid1450
Thanks for the heads up if I ever have to do that again I’ll order that stuff
Sorry to hear you got COVID, take it easy and get well quickly.Still waiting on stuff like seats, tires, brake pads, led head lights, wiring harness, and other things but ended up getting covid on Friday so I’ve been sick for the past few days does anyone know how the shifter cable bracket mounts on the transmission? It’s a f23
I have Kirkey 47 Series seats in mine. The driver's is mounted on the donor's sliders using an aluminum plate. The passenger seat is wider and couldn't be installed the same way, so it uses the Kirkey side mount brackets and some L-track.Who has kirkey aluminum seats installed? And how did you mount them ?
With the padding is it comfortable? I’ve used these before without padding only for short periods of time like to race 1/8 mile but to use for extended periods of time like a hour or two of driving?I had used the Speedway Budget seats, made by Kirkey, 17.5 wide seat.
I thought I had posted about installing them but i found that i hadn't.
Mounted using the DF seat mounts. Side mounted.
To get the drivers seat centered to the steering wheel, I used both of the left mounting tabbed brackets.
In the right side slots.
You may want to reverse the bold on the lap belt on the putter mounting point if you plan on putting side on. Once the sides are on there’s no room to get the bolt out.I had used the Speedway Budget seats, made by Kirkey, 17.5 wide seat.
That is absolutely correct for anyone using the DF side panels.You may want to reverse the bold on the lap belt on the putter mounting point if you plan on putting side on. Once the sides are on there’s no room to get the bolt out.
The foam padding in my seat covers butt area is minimal at best. You'll want to add some dense foam padding between the seat and the seat cover.With the padding is it comfortable? I’ve used these before without padding only for short periods of time like to race 1/8 mile but to use for extended periods of time like a hour or two of driving?
Dunno if you received a response. This is how i mounted my bracket. Not sure if it is correct as no one was able to verify mine.Still waiting on stuff like seats, tires, brake pads, led head lights, wiring harness, and other things but ended up getting covid on Friday so I’ve been sick for the past few days does anyone know how the shifter cable bracket mounts on the transmission? It’s a f23
Yup always Keep a spare for long trips in any car I’m driving just in caseWait...1, 2, 3, 4, 5 wheels? Are you planning to carry a spare?
