Will you be installing a roof rack or ??? Not much room except the passenger seat inside a Goblin.
There are 2 plugs on the power steering. I forgot to plug one in on my first start. Got nothin. Plugged it in and it fired right upOk I also have a “power steering “ message on the cluster , but there is 3 8 pin connectors that look exactly the same.... does anyone know what goes to what?
Those 3 connectors are easily mixed up. The "power steering" message is telling you that you are having communication issues on the GM high speed LAN. I have had these issues. If you turn the key on, and jump the starter motor (Purple wire, below), will your car start? Mine does when the LAN is not working.Ok I also have a “power steering “ message on the cluster , but there is 3 8 pin connectors that look exactly the same.... does anyone know what goes to what?
The starter motor uses a purple wire on the solenoid... that can be hot-wired to crank the starter motor.What are some people talking about a purple wire?
there is a pink wire bundle right by the rear brake line T. And a purple accessory wire by the fuse box by the engine, but other than that I have no idea
What donor? If it’s an SC, make sure you have the brake and the clutch switch connectors not swapped around. We did that and the car would only start without the brake.Ok this was random AF if I hold the brake and the clutch it won’t start lol but just clutch and it starts and runs... ignore the mess of wires still have to tidy up the wiring once everything is good.
http://instagr.am/p/CPg9kfJHRLz/
By chance, did you jumper the fuel pump relay to empty the gas from the donor when you disassembled it?Ok I got it to crank and the low fuel and power steering message is gone but now can’t get the fuel pump to prime. Swapped relays and checked fuses still nothing
Nope i bought it and got a 1/8 of a tank of gas then I drove the donor home pulled in the driveway with the gas light on lol, living on the edgeBy chance, did you jumper the fuel pump relay to empty the gas from the donor when you disassembled it?
