I have read that the balance shaft delete only saves less than 1hp on a dyno. But if you eliminate the water pump from the crankshaft, you can gain more hp... maybe 5 or 7 hp? The stock shafts are 4.2lbs each, about 10" long, so you can save some rotating weight.
The neutral shafts are $280 from ZZP, and are easier to install.
The full balance shaft delete kit is ~$150, or the half kit is about $40, but takes more time to install. You also get to choose if you are installing the sprockets as idler gears, so that the stock water pump is powered by the chain, or if you are going with an electric water pump, and removing the chain driven water pump.
Each of the 2 balance shafts have 2 bearings, numbered 1 and 2 here.
The pressurized engine oil enters one side of the bearing, and leaves out the other side, thru passages in the block.
So to maintain the oil pressure without a balance shaft, something has to fill the bearing.
On a neutral shaft, the front bearing (#1) uses the stock part around the bearing, and the stock sprocket. (those stock parts are in the image above)
the rear bearing #2, is filled with the rotating neutral shaft.
On a balance shaft delete kit,
the front bearing uses the stock part around the bearing, and the stock sprocket is bolted to the supplied part 1 (below). Some kits don't include this part, as they expect you to cut it off of the stock balance shaft. The front sprocket is only supported by the front bearing, as there is no shaft going to the rear bearing.
The rear bearing, is filled with the supplied part 2. It doesn't rotate, but the oil can travel around it, maintaining oil pressure. I have seen youtube videos pounding these aluminum rings in place with loctite, but others just use dry ice to shrink them before inserting in the block. If it falls out, your engine will loose oil pressure, so don't goof this up.
