Good Evening,
I posted a smaller portion of this (July 2, 2016). Basically they are my notes from the electrical portion of the build. Seeing that I was working on the original harness for the Goblin I updated a lot of my notes plus I was sick of trying the chase down where a wire started and terminated inside of the wrapped harnesses. First I’m not that great with a multi meter plus it always seem to be a distance that I can’t reach both ends any way.
So here goes...
This will actually be 12 individual posts.... one for each of the major plugs or blocks...
Starting with the BCM
1. BCM Blue Plug J1 Body
2. BCM Blue Plug J2 I/P
3. Red Rectangular Block on BCM
4. White Rectangular Block on BCM
Next will be the ECU Plugs
1. ECU Black Plug J1
2. ECU Grey Plug J2
Next will be the Main Fuse Block (blocks)
1. Large White Rectangular Block on the Main Fuse Block
2. Large Black Rectangular Block on the Main Fuse Block
3. Square Black (Grey) Block on the Main Fuse Block
4 Small White Rectangular Block on the Main Fuse Block
5. Headlight White Fuse Block (didn’t update this but still useful)
Lastly just some of the Misc. Connectors which had wires coming from different plugs or blocks
So this is the starting point...
Hope it will be helpful to someone out there..
THX,
Bruce
