Good Evening,
Alright that is the end of the electrical notes. I tried to use the OEM Orientation and numbering (lettering) if I could or even if I could see it. If I couldn’t everything is oriented to each other so they are completely interrelated. From everything together you could probably start with new plugs and blocks and be able to build the wire portion to lengths of your desire.
This is just me so there may be discrepancies (give me a call or text and I’ll update as necessary) there are also some ”?” if you have the location or the correct connector name again let me know and I’ll update.
THX Again,
Bruce
[email protected]
You have to get though this to get to...
THIS....
Above are 13 individual posts with each of the BCM, ECU and Main Fuse plugs and fuse blocks. Broken down into wire color codes and where each of those wires begins and terminates....
