baustin
Since I've prepared this week to have work on my goblin, I decided to also attack the rear brake calipers to get my parking brake working evenly. I can't actually find the thread/post right now but my passenger side solstice caliper only rotates the parking mechanism 50% of the travel and hits a hard stop. The driver side rotates 100% and then stops. I originally assumed this meant the passenger side had the issue, something wrong with the internals since adding washers to shorten the cable didn't make a difference. I disconnected the cables at the caliper and rotated the parking mechanism with pliers: passenger side was impossible to rotate beyond 50% and the driver side easily went to 100%.
I ordered a replacement passenger side caliper and went through replacing it and then found the new one did the exact same thing. On my workbench both new and old easily rotated the parking mechanism 100% with pliers. At this point I should've known what was going on but after being a little tired I didn't realize it. I then dissassembled the driver side and reattached it after everything checked out on my workbench the same as the passenger side calipers. When reinstalled it still rotated 100%. So I made sure to do a couple tests:
setup: both rear wheels off, subframe sitting on wood blocks, transmission in neutral, engine off, wife in the driver seat, brake fluid lines installed, parking brake cables disconnected
brake fluid clamping:
driver side caliper off, passenger side only: axle couldn't rotate
passenger side caliper off, driver side only: axle couldn't rotate
parking brake cable test:
driver side disconnected, passenger side pulled fully (50% rotation): couldn't rotate axle
passenger side disconnected, driver side pulled fully (100% rotation): axle still rotates
So what I've determined is that the driver side solstice brake caliper isn't properly actuating by the parking brake cable. I had initially though the passenger side stopping at 50% of its rotation range was the problem but instead the driver side rotating the full 100% of it's range is the bad thing. So I now need to return the newly purchased passenger side (18-B5051) and get the driver side (18-B5050). Oh well, the return should be easy but it means I spent some time learning and some time working on an already functioning brake.
