Maybe Brad will find out. I would have to look at the parts and see if it could be done.Well done, Ross.
I assume this would still work with a quick release that is set up to transfer the electrical signal? For a horn at least.
Yes, any clock spring will work with any quick release given some modifications. The only thing I am trying to accomplish is adding a clock spring to a DF steering column setup. If I am not mistaken, Ross is using the stock Cobalt tilt steering which is why he can use the stock Cobalt clock spring. With the DF steering column setup, and the NRG hub, the Volvo clock spring setup works better due to its smaller size.Well done, Ross.
Depending on what info I am after, I have been using either proprietary software and hardware written by my work or a software emulated TECH2 tool (subscription info HERE) and MDI2 from GM (HERE). The specs for decoding the data are not listed anywhere, I have just been reverse engineering the data as I go. This all said, there are several CANbus hardware interfaces on the market with various software packages that will let you explore the HS CAN bus, but it is much more tricky to find anyone who sells hardware or software for the Low Speed GMLAN bus.Hi Brad. What software do you use to listen data bus? And where I can find specs for the data? Thanks.
Thank you! I just had someone 3D print one as a test. I want to finish verifying fitment once I can pick up the proper hardware and then Ill send the file over.If you send me the file I can test cut one out of aluminum plate.
Nuker-
My buttons are built into the wheel I am using...I have the NRG steering wheel hub too. Will the NRG horn button fit with the locknut? Or are you going a different route with mounting the button?
I require a safety glass windshield, so it will be custom, whatever it ends up being. The nice thing is I can easily swap in different length tubes as I dial stuff in.By cutting down the steering tube also puts the steering wheel closer to the windshield, if you are using one.
Thank you for this info! My hood is tucked away and I had not yet had a chance to test fit it. If there is close to 2" then I should be good to go. The motor does not protrude more than an inch. I will have to modify the under hood fiberglass heat diverter.Looks like the lateral shift in the steering mount bracket did push the motor outside the frame, but it looks like it may still clear the edge of the hood. The hood sits about 2 inches away from the frame.
Bump.Thank you for the photo. I verified that the motor sticks out just shy of one inch at the furthest point. Looks like I can leave it as is!
Next up, I need to wire in some 24 ohm 25W resistors for the tail lights and CHSML. I'm just trying to decide how and where I would like to mount them.
