1. I am guessing that the'oval' shaped plugs go into the master cylinder. To get the rubber gaskets to go in I had to use a little tire wet, and they slipped right in. I can now get them in and out by hand since they are slick. Is that a problem? Are they under pressure?
2. What does the mounting bracket look like? Where does it mount?
3. Do the right-angle nozzles go to the master cylinder or the reservoir bottle?
