comegetjoe
Diggin those plaid seats!!
They are Corbeau RRX seats. They recline and I have the Corbeau sliders. I'm 5'9" with a 30" inseam. I can move them closer to the front so I can comfortably reach the pedals and recline back further than the non-reclining Corbeau seats which gives me more space between the steering wheel and my torso. Have tons of room behind the seats since I have an extended frame.Diggin those plaid seats!!
Ill have to keep your combo in mind.They are Corbeau RRX seats. They recline and I have the Corbeau sliders. I'm 5'9" with a 30" inseam. I can move them closer to the front so I can comfortably reach the pedals and recline back further than the non-reclining Corbeau seats which gives me more space between the steering wheel and my torso. Have tons of room behind the seats since I have an extended frame.
The plaid reminds me of the GTI patterns and is more fun than solid black. I like them.
Was it hard to cut those mats up for the floor? I really like that idea. I have the same mats under my weight lifting equipment. Hard stuff to move, but soft and durable.So, finally had some time to work on 2.0. Between 2 kids and all the family commitments, it has been extremely busy.
Got a solid 8 hours in on the Goblin and completed the following:
Also, ordered the updated bell cranks for the shifter.
- installed floor panels
- Used the 3m adhesive that is in the new video's. That crap is sticky and gets black stuff everywhere. Advice, let it dry then use a tool that is softer than the powder coat to remove, like a fingernail.
- installed steering rack
- installed steering rack limiters
- I didn't have a "thin enough wrench" so I used a pipe wrench. Left some marks but they are under the boot so the next person to see them will be the person rebuilding the rack in 15 years.
- installed power steering unit
- out of all the parts that I had powder coated, I missed the bracket for this. Quick shot of matt black and it went on the car. Kind of buried in the dash so, no one will know. Unless you read this build log ;-)
- installed collapsible steering column
- had to use a spare bolt I had since I crushed the threads putting the bolt in. For some reason, I have lots of spares.
- installed pedal box
- installed gas pedal
- little worried that I will have to do some sort of ecu calibration with this since it came from a parted out car on ebay.
- installed clutch pedal
- Had to bend the mount about a 1/4 inch for the pedal to clear the collapsible steering column.
- ran hard brake lines
- installed brake booster
- chose not to paint it this time. Cleaned it up and it looked decent. Plus, it came from a random parts car on ebay and I do not know if it really works.
- installed master cylinder
- painted radiator
- used a can of aerosol wax and grease remover to clean up the radiator and then painted it back with Eastwood radiator paint.
- prepped fuel tank for install
- new video clarified that I had installed the old pump incorrectly in my first build. Used a new pump and assembly went smoothly.
- installed the fuel filler neck
- How did I powder coat this part and not the power steering bracket?
When I built 1.0, I installed the floor from the bottom. This time, I flipped the frame over and put the floor on. Definitely easier to do it this way. Then, my neighbors helped flip it back over. Fortunately, they had several people over at a baby shower and several need a 15 minute brake.
During the week, I hope to get the radiator lines ironed out, install the radiator, mount the fuel tank, and possibly install the engine.
Oh, in 1.0 I had used rubber horse stall matt for the floor of the car. All the pieces except for one made it home. Fortunately, I have enough scrap from the original build to make what I need.
I cannot speak highly enough of the new build videos. Clear, concise, short, and just the facts. Not that the older ones were bad, but the new ones are great.
View attachment 28318View attachment 28319View attachment 28320View attachment 28321View attachment 28322View attachment 28323View attachment 28324View attachment 28325
I liked how the mats turned out. Really not that hard to do. Initially, tried to cut with utility knifes and such but then tried the cordless circular saw and that worked like a champ. Had a decent count tooth blade and just went nice and slow. Also, used a straight edge for a guide to keep the cuts nice and straight. Then, used a jig saw to massage any corners or minor cuts as needed. And cut them outside, it will smoke. Hope you like the smell of burnouts ;-)Was it hard to cut those mats up for the floor? I really like that idea. I have the same mats under my weight lifting equipment. Hard stuff to move, but soft and durable.
Would you recommend doing that?
Those bars are actually from the all-terrain kit that DF used to make. Do they add stiffness, sure. Are they necessary? According to my wife they are.I just now chased down the mod to your new frame, Ross bars? as good a name as any and an elegant and functional addition IMO. I wish you and others from the North Houston crew could have made it to Galveston as it appears I won't be haunting the coast next Christmas. It coulda been cool, No Worries! Pleased to see your recovery continues. Keep on Dreamin' Y'all!
Its a good solid orange with a little sparkle. Not to obnoxious but Definity looks good.Love you color scheme looks good. I am going with orange as well, not my choice cause I let my kid decided haha. Is your orange a nice bright orange? We originally wanted to go with Glow Orange, but found out that its not a UV stable color and didn't want to worry about fade. We ended up going with Orang Soda. As bright as we could find without ordering every single orange sample Prismatic has.
Is the DF shifter setup really that much of an upgrade from his aluminum setup?You bought 2 DF shifters, because you couldn't make up your mind as to what color looks best?
Gonna find out. Sick of missing 5th. Hopefully, it is shifter driven and not a transmission issue. If it is, then I'll have to find an f35 with less than 167k on it.Is the DF shifter setup really that much of an upgrade from his aluminum setup?
The pink one is Rttoys.You bought 2 DF shifters, because you couldn't make up your mind as to what color looks best?
