What ohms and wattage?On my personal goblin I used a load resistor hooked to the chmsl wire and the cruise worked.
So if I'm using an aftermarket (LED) light, I just need to add a resistor in series to bring it up to ~100 ohms if it isn't that high?For anybody who wants to mess with resistances in combination with an aftermarket CHMSL, the current draw through an equivalent '00 Chevy Impala brake light is 115mA @ B+. This puts the equivalent resistance to ~105 ohms. The equivalent resistance at 1V is ~8 ohms which lines up with what Lonny posted, but that's only if you want to do away with your brake light.
Oddly, I measured mine and I got different results. On #2, I got basically 0vdc on an open circuit. The other two were the same as your result.Lonny brought this up somewhere. Im not sure you can use a simple load resistor. The brake wire tees off to your ECM, and it doesn't appear to be a simple on/off circuit. I found three different states to really make things interesting.
1. 1V with light connected and brakes not applied .
2. 7.5V open circuit voltage and brakes not applied.
4. 12V with either light disconnected or not and brakes applied.
I'm not sure what the ECM needs to see and how it uses it to determine if cruise is or isn't activated
Most likely. Kaleb programs the plasma cutter at school and has to manual program it using it's proprietary software. There is some ability to be able to import certain files (2D) but that depends a lot on the machine itself. If you have a 2D file, it couldn't hurt to take it to them.Just a general machine shop question before I stop by one tomorrow. I designed a gauge cluster surround for all my switches using poster board.
I would like to have a nice finish cut on it, but I don't understand how the cutout I have can be turned into machine language. Will it have to be manually drawn by a designer in something like CAD?
No. That's the same style that I am currently using.Short shifter yumminess.
Any foreseeable issues with the bottom linkage ball coming out straight down as opposed to 90 degrees with the stock one?
