Still working on the main harness. I built the patch cable from the C201 connector to ECM today. I have nearly 30 wires now going to the dash. Some of the sensors (brake fluid, parking brake, coolant level, ect. now need to go straight to the AIM; as it doesn’t pull that data from the CAN bus. Also had to tap into the turn signals and hi-beam circuits for the indicators as well.
I wired up my cooling fan relay. I wired up the L2A pump using the old circuit (since I am using an LSJ fuse box.) I wired my new L2A cooling fan using the original rear defog relay. I wired the CMHSL circuit using one of the (now unused) windshield wiper relays. I built a junction plug for the courtesy lighting using the old GT 150 headliner conector, as I will actually have 7 courtesy lights, lol.
About 75% done with the harness with well over 100 hours in it, lol. I still need to wire the lights and build some connectors for CPP, BPP, and a few more. Still need to add the two 18 pin dash connectors.
I hope to power the entire harness, BCM, ECM on my work table soon and start live testing the circuits.
