So close better get done in the morning, by the afternoon that 95 degrees is going feel downright chilly!
My 4600 CFM swamp cooler will get it down and keep the garage in the low 80’s all day long mid summer as long as I kick it on early.So close better get done in the morning, by the afternoon that 95 degrees is going feel downright chilly!
I will need to do this so I'll bookmark this thread and get with you when the times comesYes it can. Anything the dealer can do as its essentially the same tool they use.
That is a Derale 65860 liquid cooler with a 500 CFM fan. I plan to use that as my liquid cooler from the L to A cooler. Had to move the fuel tank over slightly to fit it.Is that an oil cooler in the last pic? Can you share which one you went with?
Did you do any other mods related to cooling?
This car has taken every bit of automotive skill I gained growing up over 8 years working in shops under some very skilled mentors, added a few new skills, and given me an unrealized amount of passion & motivation. Its the most challenging project I’ve ever partaken and the benchmark for everything in life I am excited about. It makes my day job seem easy, lol.This is the essence of this kit. For each to make it their own and do it their own way. And this is a great example of that. I love the very custom wiring. Not something that you see often nor is actually talked about. Great job!
That is so PRECIOUS your daughter helping you with the build. I am so happy you get the opportunity to share this with each otherHarness is in! Made all the forward connections and routed the harness. Still need to find a fuel pump connector and run the lighting wiring. Hope to hook up the battery by Saturday.
All downhill now and my brain can finally rest from all of the craziness this past month.
View attachment 15261View attachment 15263View attachment 15264View attachment 15265View attachment 15266
Brian, yes it is hot in AZ and we don't get many working hours in during the mornings before we get chased out of the garage when the temps get past 100.Not much to talk about right now. Still have to add the fuel pump connector (btw, if anyone needs the proper part # for the LNF one, I have it). Its still hot out, but mostly drained this weekend because work has been super busy this last week as I'm now filling in for people who just went out sick due to this covid bullshit and social distancing at home from my wife who is high risk.
I picked out my headlights and will probably order them today. I'm also going to start looking at wheels & tires.
I talked my neighbor into installing a factory fuel injected 5.0 in his 78 Cobra. We found a builder block today and will go pick it up. Any Ford nuts in here? May need some advice on this build in regards to heads & internals. It sounds like he has a fair budget and he will make awesome track & car show company later on once we both finish our builds.
I'm still not sure on the wheels & tires. I've revisited that one a few times now. Tires? sticky ones! I'm going with a 4x100 bolt pattern and so far I like the Enkies & Konigs.Brian, yes it is hot in AZ and we don't get many working hours in during the mornings before we get chased out of the garage when the temps get past 100.
Good to see you got the correct connector to get the fuel pump fixed, hopefully it will work.
Any ideas on which wheel/tire combination you are leaning toward?
Stay cool and do a rain dance, we need it desperately!
put an LS in it.I talked my neighbor into installing a factory fuel injected 5.0 in his 78 Cobra. We found a builder block today and will go pick it up. Any Ford nuts in here? May need some advice on this build in regards to heads & internals. It sounds like he has a fair budget and he will make awesome track & car show company later on once we both finish our builds.
Carid is the bomb. I got my wheels, steering wheel, adaptors and headlights from them.CAR ID HAS SOME NICE WHEELS THAT SIZE
I like when you call and they say CAR-ID , Then I say oh that’s how you say the nameCarid is the bomb. I got my wheels, steering wheel, adaptors and headlights from them.
now I‘m looking at stuff for my truck
