GM only. Not taking any chances.Which fluid did you put back in the tranny? I ended up going with the GM stuff and it was expensive!
That will most likely interfer with the upper radiator hose.I removed my Derale heat exchanger from the left side to check fit on the right side. Looks like it just clears and will still allow room for the refuel hose. This is GREAT news, as this means I will be able to run 2 of these; one on each side. I think this configuration will be adequate for keeping my L2A and IAT2 temps down. I will have to relocate the air cleaner slightly, but I would rather be pulling fresh air from away & outside of the engine and cowling area anyways.
From what I can tell with all of the reference pictures I took of Rich’s finished Goblin, it will be close, but should just barely clear. I plan to hang the engine this weekend for a test fit. If it is too close, I can always go with a slightly narrower heat exchanger.That will most likely interfer with the upper radiator hose.
That would be great; thanks. A straight side shot would be good too. The cooler is pretty narrow at the point where it will be near the rad hose. I can come in about 1 1/2” by modifying the lower tab if need be. Rich may have his hose run slightly different but that is all I have to go by.I can take some shots directly from above with the sight line if you would like.
I’m most likely going with an anodized chrome on the frame and an additional 2 step anodized blue coating on the control arms and brackets. I want it all to look like aluminum.Nice! What color are you going with? What is your goal for completion?
Thats a nice idea. I’ve got something in the works right now to where I am going to attempt to bench test my heat exchanger and the df supplied one to measure their effectiveness under various ambient temperatures.
