You need a 93 tune, your injectors are probably fine. Get with AL McClure with ZZP and he may be able to give you a PCM recalibration. He probably already has the files for that car.It’s the goblin I bought of Ken Leiker he ran E85 with a 3 Gall tank. So I was wanting to use a regular goblin tank.
Plus E85 is so hard to find.
It’s a 2007 supercharged
Al McClure at ZZP did it and Ken give me all the tune info so that helps,Yeah, your LSJ engine only knows how to burn 1 fuel. Right now it will be programmed for E85, and will run pig rich on gasoline.
Not sure who tuned your engine to run on E85, but that should be re-tuned for gas.
