Hey r3drckt I want to do the ZZP TC swap also how did you build come out and what will I need to do to achieve it thanks in advance.Be better to turbo swap the LSJ. That’s what I’m doing. Intro kit with the K04 from ZZP is around $1800 I think.
Haven’t finished the build yet unfortunately. Life has it on the back burner at the moment. The kit comes with everything you’d need to remove the SC and put a TC on the LSJ. You retain the factory Laminova cores and intake, the kit comes with the new exhaust manifold, turbo, turbo oil lines, and intake tubing though. Otherwise, your goblin build proceeds just like the normal SC build. You’d still have to run the tubes down the middle to the heat exchanger in the front (or where ever you mount your heat exchanger) and run the heat exchanger coolant pump used in the factory SC setup.Hey r3drckt I want to do the ZZP TC swap also how did you build come out and what will I need to do to achieve it thanks in advance.
I purchased the SC kit because it’s what my donor was. If you plan on going with a normal A2A turbo configuration, then it may not matter. Either way, you’ll want to message DF about your intention to turbo swap so they can include the turbo muffler instead of the SC muffler. I forgot to do It so I will need to have one welded onto the muffler or a custom one made.Did you need to buy the SC or TC kit from DFG? I am planning this build and trying to figure out what all I will need to get.
