ccannx
I can confirm that a pressure plate failure is detected as knock on the VCM scanner tool...
You Tube Mashup Video
Good videos!!!Got to test out the Goblin weekend before last just had a chance to upload July 4 2021 in the goblin. This was to test some suspension and steering adjustments. I cracked the waste gate open 1/2" just to run the car momentum only and still waiting on getting a local dyno tune to make sure I'm running safe at full power. Even with the loose rear over bumps and lack of power I was still only .5 seconds behind our fastest local EM competitor in the Fiat. Video Here : Goblin Easter run
I headed out to Verona Va this past weekend and took the c5 z06, the Goblin is scheduled to get a Dyno tune at the end of June. Took 1st place in Cam-s, 2nd overall, 2nd place Pax and managed to outrun all the fancy new C-8 corvettes. This course was super tight and would have probably favored the Goblin much more than the corvette. The corvette did good, I don't consider it to be a fully prepped Cam-s car so getting beat by a miata piloted by Tim Aro is acceptable. The Yokohama a052 tires are amazing ! Video Here : C5z06 BRRSCCA RUN
There's a whole sub-forum dedicated to tuning.I have an ebay cheap ls4 throttle body and tried to run it by changing the scaler area but it kept going into reduced engine power for no apparent reason from the data logs . Put the lsj throttle body on and it had no issues at all. I cut corners and used a cheap 3inch id diameter silicon tube from autozone and it popped off on a run when I was turning up the duty cycle and was not able to take the pressure.
I want to attach a copy of my last VCM scan to get some feedback on adjusting the MAF. Also ordered a 3bar map to try to get the VE tuned in addition to the Maf values but know that's going to be more involved. I think there is an area in HP tuners to rescale the maf by voltage output. I recall a tuning thread on here somewhere for HP tuners there is also a group on facebook that may be helpful to bounce questions to.
Using the gfab2 electronic boost controller to program how the boost comes in. Sensitivity setting will attempt to hold boost at the target level by adjusting the wastegate duty cycle.Lowering the sensitivity of what?
Yeah, I am still modifying my car to get more rear traction. The opposite issue SmsDetroit was having.
The front swaybar helped transitional rear grip but if I go any stiffer it goes into understeer.Lowering the sensitivity of what?
The AFR's are going lean while Inj Duty cycle is following the Maf curve. I'm not sure how much the pressure should change at the rail but I guess if the reference is 20psi shouldn't the rail pressure also go up 20 psi ?When you say loosing fuel pressure, are you talking about actual rail pressure or AFR going lean? Sorry I haven’t read back through all of the post and just jumped in here. Looked like you had good pressure there. You may consider a new fuel pump. We had to replace it twice in two years before everything was good.
Yes, the fuel pressure should proportional with the boost. It looks like your is working correctly from what I can tell from the video.The AFR's are going lean while Inj Duty cycle is following the Maf curve. I'm not sure how much the pressure should change at the rail but I guess if the reference is 20psi shouldn't the rail pressure also go up 20 psi ?
While looking at this post, my daughter Zelda asked what I was looking at. I said, "Someone isn't happy with the way his car running." (She's 5, so simple explanations work best.)The base pressure is set at 43.5 PSI with the reference line disconnected. Duty cycle is around 56.2 at 22psi and 6200rpm. There is still plenty of fuel that can be added but I'm not thrilled about how jagged the AFR lines look.
Attached is a log of it running lean.
At first I suspected your wideband as the O2 is not reporting that lean at this very instant but upon further thought, I don't think the O2 is responding as fast as the wideband because it is showing leaner AFR during the period of the ripple in the wideband AFR. The ECM is commanding 12 and it was getting it for a moment and then looks like it struggles to get enough fuel, but only very brief pulses.The base pressure is set at 43.5 PSI with the reference line disconnected. Duty cycle is around 56.2 at 22psi and 6200rpm. There is still plenty of fuel that can be added but I'm not thrilled about how jagged the AFR lines look.
That is a massive jump in power. Holy smokes!On the 999 SuperSport Mk2 LNF 2.0L engine build Jackson used the larger Opel flex fuel direct injectors and ZZP big fuel lobe cam plus ZZP Borg Warner EFR turbo kit. Ace-in-the-hole however, was Life Racing ECU and MP 109 racing fuel which netted 450 rwhp at 32 lbs boost. The ECU also has a secondary map when running 93 octane pump gas which pulls boost pressure and timing for 340 rwhp.
KAL
