Could one of you gurus help a fella out? I've got some VAC hose routing questions.
1. This larger connector below the throttle body is for brake vacuum, correct?
2. What will this smaller connector above the throttle body be used for? I think it went to the purge valve that was OEM.
3. I need to route a hose from this crankcase vent over to the turbo, correct? I swapped heads and the vent is on the wrong side now. Blurry and in the background is the hose that ZZP had connected to the other head crankcase.
4. On the turbo. What connects here?
4a. The tan (BPV?) on the lower left.
4b. The hose connector on the left side of the black box front and center.
4c. What wiring connects to this black box?
4d. In the background behind the "flex technologies" tube, that is the hose I was talking about in #3 above. This goes to the crankcase vent, correct?
5. Lastly for this post...what type of oil sensor is this on the oil pan under the starter? What should plug into it? My donor doesn't have that at all
I guess for reference and a reminder; I have an LDK/turbo crate engine that I'm swapping over to port injection. That's why my components are all over the place.
CHRIS
