Fozda
Has anyone considered using the frame rail tubes as the method of fluid transfer by welding fittings onto the end instead of pulling hoses through them? I can't think of any reason this wouldn't work but I'm sure someone has already thought of this and reasons why it wouldn't. I know the frame will get a bit hot with the hot water flowing through it but you could always put some heat wrap or shields in the problem areas. This method should also help with cooling a bit.
