jcdman
Hey everyone, there's two different bolts for the lower crankcase to main block. I know the inner bolts are 15ft-lbs then 70deg, but I can't find a torque spec for the outer 10 bolts.
You should add your donor year and model to your signature. Make it easier to help look in ALLDATA. Here is what I have for what mine is, 07 SS/SC 2.0 LSJ.Hey everyone, there's two different bolts for the lower crankcase to main block. I know the inner bolts are 15ft-lbs then 70deg, but I can't find a torque spec for the outer 10 bolts.
2005 SS/SC. Thanks for the help!You should add your donor year and model to your signature. Make it easier to help look in ALLDATA. Here is what I have for what mine is, 07 SS/SC 2.0 LSJ.
It looks like when your using your phone you don’t see the signature. I would think these specs would be good. Same motor.2005 SS/SC. Thanks for the help!
That's the same Torque sequence from my Haynes manual for my 2.4L engine. Also says to use NEW Bolts. (Note: All in Ft. pounds)You should add your donor year and model to your signature. Make it easier to help look in ALLDATA. Here is what I have for what mine is, 07 SS/SC 2.0 LSJ.
